alot of codes with with koer test with actron tester
92pobronco
Rust country
SO I have been having some issues with the bronco while running but otherwise she runs like a top other than a sporatic check engine light flashing for a minute (reason for testing) no check engine light stored just random flashing
I recently put in a new tps, cleaned the throttle body and egr ports plus new cap and rotor and oil (still need to do plugs and wires)plugged vacume leak at rotted out coffee can under the washer fluid and coolant resevoir
ISSUES I have encountered are (severe battery drain when running heat, headlights(dimming at idle),radio all at once) - and during the rpm range of driving if I don't put the pedal in a certain spot at various speeds she clunks as if stuck between a gear or lock or unlock converter(new converter and pump last year) I dont know if the problems are tied together or what but i checked the codes and came up with
these...
31 EVP signal is/was out of range. 31-15-38-53-66-32- all key off engine running- (92 ford bronco e40d tranny 5.0l
15 KAM (pin 1) was interrupted (was battery disconnected ?)yes last week
38 Idle Tracking Switch signal was intermittent.
53 Throttle Position sensor too high.
66 Transmission Oil Temperature (TOT) signal low (possibly grounded).
Vane Air Flow (VAF) or Mass Air Flow (MAF) signal low.
32 (KOEO, KOER, MEM)
EVR,EVP signal is/was low
(KOER, MEM)
PFE shows low pressure, EGR not seating or memory, not seating intermittently.
IM gonna change the tranny fluid and filter soon: do to the metallic tone it is becoming
I could really use some guidance here to help me nip this in the bud
THANKS FOR YOUR TIME
yo!
here ya go; for now..
DTC 31 or 32 Both KOEO & KOER EVP sensor out of range EGR is sticking or EVP is bad Source: by miesk5 at Ford Bronco Zone Forums
Testing; "...Using the Haynes manual's procedures, you should be able to back-probe the EVP line and ascertain whether the EVP voltage is correct. It should be below 0.67V @ zero vacuum on the EGR, slowly increasing with applied vacuum from a hand pump. DO NOT apply more than 10 in-Hg to the valve..."
Source: by SigEpBlue (Steve)
Testing & Operation Source: by Ryan M (Fireguy50) at fordfuelinjection.com
Testing & Operation Source: by Tomco Inc. tomco-inc.com
DTC 31, 32. 33. 34. 35. 38 or 84; EGR Valve Position (EVP) Sensor & EGR Vacuum Regulator Solenoid (EVR) Testing Source: by Dustin S (Dustball, Mellow Yellow, Mr. Laser Boy) at ylobronc.users.superford.org
15..as you wrote..batty was discoed?
ECA KAM failure
Battery dead or disconnected, bad ECM relay or fuse
18 (rc): Loss of TACH signal from TFI (Thick Film Integration- the module on the side of the distributor). There is an open in the SPOUT circuit. Suspect SPOUT connector - go to my site and under Spark Output (SPOUT) ConnectorMy link for more Testing / Troubelshooting LINKS
DTC 53 (KOEO) TP sensor out of range TP sensor is stuck/sticking or just plain bad
See the testing Links there
32 EGR sticking open, bad EVP/PFE sensor, clogged exhaust or convertor
DTC 32 or 326; "...DTC 32/326 typically means that the EGR valve is not fully seated. This can be due to a bad EGR valve, vacuum trapped in the EGR hose, a clogged EVR filter, or a bad EVR solenoid. It is also important to note that if you have an exhaust ventilation system hooked up, that this can also cause an inaccurate reading. Try disconnecting the system and retesting..." Source: by tomco-inc.com read it for Testing...
For all Emission (EVP, EGR, etc DTCs, go to my site and under Emissions, go to Exhaust Gas Re-circulation (EGR) System for more Testing / Troublsshooting LINKS
66 Transmission Oil Temperature (TOT) signal low (possibly grounded). NOT APPL
Vane Air Flow (VAF)
or Mass Air Flow (MAF) signal low. NOT APPL[/b
Suggest re-do of Self Test
will be back Sat morning to see if I can add more.
GL
