Smurfette..,
Now that's interesting....in that most folks don't know what an "oil-bath" air filter is....
Long/short., truth told., that's the best automotive air filter ever designed/made. (I still have mine & wouldn't part with it) [-X
If yours needs some slight repair & the fibers are in good shape...clean it up & use it.
The reason it was phased out is because there was no $$$ to be made for replacment filters.
I clean mine a couple times a year & use automatic transmission fluid but motor oil works fine.
ALSO., it's tricky fitting a filter large enough to clear the hood,but doable. (assuming you have the stock carb.)
Lastly.., these days, they make mega $$$ filters that you
"soak-in-oil" ..!
And yah., they claim all this improved performance & HP...!!!!
If ya believe that., there's a bridge there in NY I'll sell ya..... :lol:
OOPS., I forgot..., I have seen pics of this filter "jerry-rigged" with a fiber filter somehow attached to the bottom, in place of the oil section.
How well it worked, or sealed, I haven't a clue.
HTH
