Try the
reading the Air Bag Code again;
Warning; * The air bag diagnostic monitor includes an internal backup power supply. This feature provides sufficient backup power to deploy the air bag in the event the battery or battery cables are damaged in an accident before safing and primary crash sensors close. The backup power supply will deplete its stored energy approximately one minute after the positive battery cable is disconnected.
In case it is DTC 33 TSB BC0326961129 for 94-96 Bronco & F 150; "...When diagnosing an air bag lamp flash-out code 33 (passenger side air bag high resistance or open) on a 1994-1996 F150 or Bronco that is not equipped with a passenger side air bag, check for proper ground from pin 7, circuit 629, at the air bag diagnostic monitor connector c218, to the negative battery post; NHTSA #50734 ..."
Source: by Ford via miesk5 at broncolinks.com
Wiring Diagram by Ford via Steve83; showing pin 7, circuit 629 @ connector c218
I have other air bag info incl some code possible cause & troubleshooting in my site @
http://www.broncolinks.com/index.php?index=109
