brentusbrutus
Just looking for a bit of advice..
I took out my fuel sending unit. Found out it was leaking where it connects to the gas line. I am planning on JB Welding it around the metal line . (it is leaking at the base of the line)
I also want to get my gas gauge working working. My first thought was to drill a little hole where the existing hole was, and then put a small bolt through, then attatch the lead from the fuel sending unit to one side of the bolt, and attatch the fuel gauge wire to the outside of the bolt, then JB WELD the **** out of the Bolt to try and seal it in.
I kinda put this idea across to a Canadian Tire Parts guy when I was buying my JB Weld, and he said I could blow myself up because of the metal on metal.
I am now thinking about JB'ing an insulated wire through the tank.
What are your thoughts?
Take a look at the Pictures and tell me what you think...
P.S. Hopefully the Pic will show when I actually post, if not, you might have to use your imagination.
/emoticons/smile@2x.png 2x" width="20" height="20" />
