Abs on 1995
1995bronco
where do you unplug the abs on a 1995? i broke my speed sensor and do not want to pay $140 for another one, so i want to just unplug the abs system.
50joe
Trenton NJ
You don't. If the speed sensor, (front I'm assuming for the price), isn't working, the computer recognizes it, and it will trigger the ABS light, and disable the system.
1995bronco
well it is not disabling it, all it is doing is trying to to lock up my left side because it thinks my right side is locked up because the sensor is nnot working
1995bronco
miesk5 said:
If that were the case, it would also be locking the rear brakes. You probably have a mechanical fault in the brakes or suspension. I suggest you ID & fix it since disabling the ABS won't, and will probably result in damage.
But if you're dead-set, just unplug the 2 four-pin connectors at the HCU on the frame rail in front of the LHF tire.
thanks found it and unpluged fixed my problem, and yes i destroyed the sensor while changing the upper and lower ball joints.
Motormouth2025
