ABS Light
94broncobeast
My ABS light keeps coming on and off every so often. Is that something to worry about? Also how do you check for codes?
firelt90bronco
Ask me about my job
northeast
Well, based on a professional opinion, the ABS light could be telling you the brakes may have problems. I worked on a car with a constant ABS light and the cause was air in the lines. The ABS unit could also have a problem, the best solution is to bring it to a shop for service. This will cover your a$$ in the future, if the car wrecks (god forbid) there is more legal leverage than you trying to fix it in your driveway.
bigtrux
Murrieta,CA
Also check your parking brake make sure it's all the way up and there's no movement in it ..
Ford644
