ABS Brake system
Daddude
Once in awhile the ABS light goes on but I have braking during this. At other times the pedal about reaches the floor and during this theres a flutter in the pedal as its going to the floor.The brake fluid is fine and the discs are within specs.This happens very seldom .Whats going on? I hate dealers and there high prices!! :eek: /emoticons/[email protected] 2x" width="20" height="20" /> :eek: /emoticons/[email protected] 2x" width="20" height="20" />
B-Cack
I have kind of the same issue, someone in here told me that it is possibly the ABS sensor. It is located behind the nub you would use to bleed the brakes, I am going to check it out this weekend, will keep you posted.
Raul J. Puertas
24724[/snapback]
I have a similar problem and I had it check out in MIDAS. First of all they charged me $100 jus to make the diagnostic. and they told me that it is the ABS Hydraulic Assembly and Control unit and it will cost me $700 to fix it.! the light is still on.
RP :-&
bew8484
Indiana
If your pedal is going all the way to the floor it is the hydralic control assembly. Mine has the same problem and it has been like that since I bought it. Very pricey fix. I was told aside from the occasional drop in the pedal nothing is hurt you just don't ABS right now. I might fix mine before the snow this year.
Brad
