A Few Repairs..
Balbronco
1. I have a 1988 Ford Bronco 5.0 XLT with automatic engaging hubs. The other day I noticed the hubs hot, almost to the point I wouldn't bear to touch it. This happened after a short one mile drive. I had to disassemble the driver side hub about a month ago to remove the rusted out splash shield and it looked well lubricated and immaculate. Before you guys think it was assembled incorrectly, both sides get equally hot and I never touched the passenger side hub. Could this be caused by bad U-joints? Normal? I am changing the U-joints in August.
2. My second problem is hesitation to start and engine RPM dropping below normal when cruising and my foot is off the gas. When this happens I can feel a bit of engine braking suddenly but for a short second then returns to normal RPM. I just did a full tune up, clean the throttle plates and replaced the TPS and IAC valve and this is still happening (however much improvement). Today the ABS light came on, but I doubt it is relevant to that problem.
3. A few days ago after waiting at a drive through I let my foot off the brake and before going to the throttle I noticed that the truck isn't even moving without my foot on the brake (yes yes it was in gear :p /emoticons/[email protected] 2x" width="20" height="20" /> ) I gave it gas and it took off normally maybe this is a sticking wheel cylinder? Relevant to the ABS light? Any ideas are welcome and I will have to run the codes on this.
BroncoJoe19
#2 Pull codes.
WHen you replaced your TPS, did you adjust it?
One of the reasons for the ABS light to come on is a sticking parking brake.
Another is a faulty or dirty ABS sensor on the top of your rear pumpkin, or poor connections there.
Balbronco
Well my parking brake needs adjustment bad it is very lose and I never heard of adjusting the TPS sensor.
Balbronco
Thank you for that thread bronco joe. This is the 2nd time my Chilton manual failed to give me correct information.. 1st was the wrong firing order and 2nd was that it never mentioned any adjustments for the TPS. Do not trust these manuals they ****.
I'm almost positive the parking brake is disengaged, but I will get under the car tomorrow and really get a good luck at it then.
