96 bronco XLT 5.8 20amp breaker hot door locks click but won't work
Juan3774
Dayton Ohio
96 bronco XLT 5.8 20amp breaker hot remote door locks click but won't work, same breaker for 4x4 switch, had same problem a year ago, pulled door switch's no corrosion put them back in ,disconnected lumbar connectors, breaker didn't get hot no problem till today, opened w/ remote, let tailgate window down, backed up hill in front yard to unload the rear locks stopped ,breaker hot again, when I put breaker back in you can see and hear slight spark and click ,door switch works then breaker trips and heats up, rerouted power to tailgate from 25amp constant fuse works fine, help would really be appreciated I'm sure some of you have had the same issue, thanks bronco buddies.
Is your remote door locks factory or add on/aftermarket?
Similar threads
T
Replies
Views
1K
Top stories on BroncoZone.com
T
T
Replies
Views
1K
T
T
Replies
Views
1K
T
79' Buckin Bronco
