96 Bronco Help Needed
swilliams
Nevada
Just picked up a 96 Bronco that has a 3" body lift in addition to a suspension lift. I need to know how to go about raising the front and rear bumpers to meet back up with the rest of the cab. there is a large gap in the front and rear and looks like ****. Any info would be greatly appreciated.
Krafty
Ontario Canada
you can either just use these.
http://broncograveyard.com/bronco/i-33337_..._body_lifts.htm
or you have to modify your brackets, or make custom ones. with the bronco rear bumper mounts I think you can just adjust the orientation of the brackets to raise the height of the bumper. for the front you will have to cut holes or slots in the bracket to make the changes.
Im not 100% sure with the 92 to 96's cause haven't had one to tinker with
S
swilliams
Nevada
Thanks for the info. Greatly appreciate it.
