yo bruuser9,
Hazard Flasher Switch
The turn indicator/hazard flasher switch is located in the upper steering column hub. The turn signal is operated by the multi-function switch (13K359) on the left side of the hub. Two flashers are used, one for the turn signal in front part of fuse panel & hazard flasher is on the back of the fuse panel, Hazard flasher is shown, but not identified in view A at bottom left. You have to reach panel around to feel it and remove.
http://www.diesel-dave.com/vehic/manual/stj/images/k17293d.gif
Item Part Number Description
1 14401 Wiring Assembly — Main
2 14401 Fuse Panel
3 14401 Wiring Assembly — Main
4 — Fuse (3 Amp) DI Diesel
5 14526 Circuit Breaker (20 Amp)
6 14A254 Fuse Panel Bracket
7 14526 Circuit Breaker (20 Amp)
8 13350 Turn Signal Flasher Assembly
9 N803876-S424 *****
The flashers are slightly different, although they,are physically interchangeable, butmthe hazard flasher is designed to handle more current.
BTW, great profile!!
