94 Ford Bronco
Hcander
Colorado
Leak is below the vacuum hoses at top of engine. I'm not mechanically inclined to my vehicle yet but working on it. The area is hard to see, but it is dripping onto the plugs. I checked what I could of the hoses all are in good shape, and I know not where the water pump is. Mechanics are few and far away where I live. Any help would be greatly appreciated. Thanks.
EB Bronco
I'm guessing that you are leaking coolant since you are checking hoses? What size engine do you have? I have a 94 with the 5.0 and I had to replace the hose that provides coolant to the throttle body. It is hard to see because it's directly under the air intake hose and is only about 5 inches long in total length. The water pump on this engine is located on top of the engine toward the front right as you're facing it. The large hose from the top of your radiator goes directly to it and the small bypass hose to the throttle body sits a little under it also. You wouldn't know the hose is even there if you didn't move some things around. I've seen a lot of those hoses crack right where the clamp is because of the heat from the engine.
Roger
H
Hcander
Colorado
Roger
20547[/snapback]
Thankyou for the info the engine size is 5.8L
Chris
H
Hcander
Colorado
Okay Roger I think I got this thing figured out (the message boards) Thank you for the information you gave me it was very helpful, It was the bypass hose as you suggested. It was a pin size hole. My Bronco is a Eddie Bauer also only it has a 5.8. I also had 32's on it but they are in storage right now, where I live I need snow tires still. Once again thanks for the help.
Chris
