94 F150 Stuck in Park
firelt90bronco
Ask me about my job
northeast
I'm working on a 1994 F150 extended cab shortbed with the 302 and auto trans. The vehicle won't shift out of park and the ABS light is flashing. The only way to shift it is to disconnect the battery and shift it to neutral and reconnect the battery. I think its a computer problem. The owner was trying to fix the backup lights and did somehting, I don't know what.
escortwgn
Shaw AFB, Sumter, SC
when you press the brake pedal can you here a clicking or feel a moving motion on top of the steering column? if not there's a switch on top of the brake pedal that when the pedal is pressed, the solenoid on top of the shifter is unlocked and will allow for shifting out of park. since you mentioned the owner working on the back up lights, do all the rear lights still work? thats about all i know about 94 fords
escortwgn
well i don't know what to tell you then try locating the switch on the gear shifter on behind the steering wheel. thats all i know. good luck!
CHECK 4wABS codes first;
look here for Links:
http://home.comcast.net/~miesk5/BroncoTech...#BRAKE%20SYSTEM
from atcdg which has closed;
"E4OD
Shift Lever Stuck in Park
Some late model F Series (Pick-up trucks) and E Series (Vans) may experience a complaint of "shifter stuck in Park".
These (and many other) vehicles are equipped with a Brake/Shifter interlock for safety. This system requires the driver to hold the brake depressed before the shift lever can be moved from the Park position. There is an actuator (solenoid) on the left side of the steering column under the dash that disengages the shifter lock when the brake is depressed. In the event this system malfunctions, the shift lever may be stuck in the Park position. One cause of this complaint may be due to a faulty brake switch circuit. If you experience this complaint always check for blown fuses and brake light switch operation before proceeding with other work."
need to go over prev owner's wiring changes....ck wiring diagram here;http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/0a/3a/41/0900823d800a3a41.jsp
other possibilites
Water Intrusion of MLP/TR Sensor TSB 95-2-12 by Ford for 89-94
01/30/95
TRANSMISSION - E40D - DIAGNOSTIC TROUBLE CODES - WATER INTRUSION OF THE MLP/TR SENSOR
TRANSMISSION - E40D - POSSIBLE WATER INTRUSION INTO THE MLP/TR SENSOR CAUSING SHIFT CONCERNS AND/OR HARSH ENGAGEMENT CONCERNS
TRANSMISSlON - E40D - SHIFT CONCERNS AND/OR HARSH ENGAGEMENT CONCERNS DUE TO WATER INTRUSION OF THE MLP/TR SENSOR
1989-94 BRONCO, ECONOLINE, F-150-350 SERIES, F-47, F-53, F-59
ISSUE: Some vehicles may exhibit a shift concern and/or a harsh engagement concern due to water intrusion into the MLP/TR sensor and vehicle harness. There may also be a number of different DTC's along with those concerns.
ACTION: Replace the MLP/TR sensor and vehicle harness connector if signs of water penetration are evident. Refer to the following for service details.
SERVICE PROCEDURE
1. Verify the customer concern.
2. Perform normal on-board diagnostics.
3. Inspect the MLP/TR sensor for signs of water contamination.
4. If water penetration is present and/or DTC's have been set, replace the MLP/TR sensor and the vehicle harness connector with the TR Sensor Service Kit (F5TZ-7A247-A).
The TR Service Kit contains:
One (1) TR Sensor
One (1) Connector Assembly
One (1) "Red" Pin Separator Plate
One (1) 6-Pin Grommet
One (1) 8-Pin Grommet
One (1) 7-Pin Grommet
One (1) Instruction Sheet
PART NUMBER PART NAME
F5TZ-7A247-A TR Sensor Service Kit
OTHER APPLICABLE ARTICLES: NONE
WARRANTY STATUS: Eligible Under The Provisions Of Bumper To Bumper Warranty Coverage For 1992-94 Models, Basic Warranty Coverage For All Other Model Years
OPERATION DESCRIPTION TIME 950212A Perform Electronic 2.0 Hrs.
Transmission Diagnostics, Replace MLP/TR Sensor
DEALER CODING BASIC PART NO. CONDITION CODE 7F293 08
Motormouth2025
