92 bronco cranks but wont start new computer,module,coil distrutor hel
waco
I have 2 1992 broncos and a 1988 my 1992 eddie bauer will not start the engine will turn over I have installed a new computer,module,coil,and distributor.i have 12 volts to the +side of coil with a test light if i jummp the + side to the - side of the coil plug in and spin the engine the test light does not flash i have chased the negative coilo wire to the plug on the drives side fender plug it slits into 3 wires the wires check good with a power off test light i do not know where to go next! ineed help please!
yo WACO,
WELCOME!
Will get back to you as soon as storms clear here.
for now;
Ford Ignition Coil Test No Spark No Start Tests
http://troubleshootmyvehicle.com/ford/4.9L-5.0L-5.8L/how-to-test-the-ignition-coil-1
to save $, Google for a DIY HEI Spark Tester using a good spare spark plug; wear dry heave gloves
also; How to Troubleshoot a No Start (Ford 4.9L, 5.0L, 5.8L) http://troubleshootmyvehicle.com/ford/4.9L-5.0L-5.8L/how-to-troubleshoot-a-no-start-1
In a no start condition (also known as a cranks but does not start)... your vehicle's starter motor is cranking the engine but the engine is not starting. This is usually due to a lack of spark, or fuel, or engine compression
Do you have the grey ICM? and is it a Motorcraft unit?
ok, have you inspected the wiring & connectors to all replaced components?
take time to go through those tests
and Try a Self Test for Diagnostic Trouble Codes (DTC)s by my pal, BroncoJoe19
http://broncozone.com/topic/14269-co...&mode=threaded
A helper is good to assist in reading Codes; best is to take a cell fone vid and replay it.
Some basics;
Visual Check
1.Inspect the air cleaner and inlet ducting.
2.Check all engine vacuum hoses for damage, leaks, cracks, blockage, proper routing, etc.
3.Check EEC system wiring harness for proper connections, bent or broken pins, corrosion, loose wires, proper routing, etc.
4.Check the Powertrain Control Module (PCM), sensors and actuators for physical damage; IAC, TPS I see was replaced, etc.
5.Check the engine coolant for proper level and mixture.
6.Check the transmission fluid level and quality. See E4OD Fluid Condition Check Below)
7.Make all necessary repairs before continuing
8. Check headlights
The engine temperature must be greater than 50° F for the Key On Engine Off (KOEO) Self-Test Make sure A/C is off and transmission is in Park (automatic); or in Neutral for a Manual & release clutch.
Turn off all accessories; radio, lights, A/C, heater, blower, fans, etc. (close driver's door)
Do KOEO test
guilhermeknob
