91 Bronco Vin Deciphering
Vlen
Hey all, i was just wondering what kind of info i could decipher from the vin, my friend just got a 91 bronco, all he really knows is that it's a 302. i can provide the vin if theres a lot to be gained from it. thanks all :blush:
OK here it goes
1st 3 characters - Manufacturer make and type
4th - character Brakes/GVWR Class
Next 3 (5, 6 & 7) Modle or line, series, Chassis, cab or body type
8th - engine type
9th - Check digit
10th - Modle year
11th - Assembly plant
12th - constant A untill sequence number 99,999 is reached then it changes to B and so on.
13 - 17, sequence number.
There is a build date stamp on the front surface of the radiator support, passenger side.
The safety compliance sticker which is on the rear driverside door post gives the most usefull info. ex. paint code, Vehicle type, Body (trim type, trim color, body style), Transmission, axle type and ratiocode.
That all assumes nothing has been modified.
V
Vlen
For the VIN im gonna ask that Burns (new member, see topic "just got it") post it as its HIS bronco! :)) Hopefully we'll get back to ya soon, and thanks for the help, you rule Seabronc! :D/
Burns
Royersford, PA
The VIN for the 90 Bronco is - 1FMEU15NXLLA01983.
Thanks to all for any/all help.
1FM = Ford Motor Company , make Ford, multipurpose pasenger vehicle (MPV)
my comment - notice it is a MPV not a SUV :) /emoticons/[email protected] 2x" width="20" height="20" />
E = Hydraulic brake system Class E 6,001 - 7,000 pounds
U15 = Line - Bronco, Series - U150, Chassis - Type 4x4, Body type - Bronco, MPV
N = 5.0 EFI 302, Cylinders - V8, Fuel - Gasoline, Manufacturer - Ford
X = check digit
L = Year 1990 (don't panic it was a 91 built in 90)
L = Vehicle assembly Plant - Michigan Truck: Wayne, Michigan
A01983 = Build sequence number (1983rd 91 Bronco built)
There is more meaning full info on the Safety Compliance Certificate located on the driverside rear door post such as weight, paint codes, wheel base (all broncos were 133 Inches), type (all Broncos were U150), body (seat trim and style, trim color), transmission, axle code, type, springs, tires, cold presure, etc.
