9" Crush Sleeve
bump74
How much torque does it take to compress a 9" crush sleeve? I've used 175ft/lbs and still have play between my pinion bearings. I need to know how much play i need if any.
Broncoholics
Broncoholics
Washington State
I think you can add a thin shim behind the pinion race so its held out further. I took mine into Randy's Ring and Pinion and thats all they had to do to mine.
I'd give them a call to be sure though. Its all in the shims!
79' Buckin Bronco
