88 bronco whining
tellfour
88 Bronco 5.8L with a whining noise under acceleration, whining goes way at idle. Removed the vacccum from the manifold absolute pressure diaphram and the whining stops. Replaced diaphram and yep, noise still there. Not sure what else to look for, any ideas.
woodtah
24300[/snapback]
I do not know what the problem is but I am having the same problem with my 85. It has a rebuilt engine in it that I have changed the PS pump and the Alternator. The belts sound like they are sqealing but it is only under acceleration. If you get any good tips let me know too.
American Rebel
4x4 Trail Master
Chesapeake, VA
It's probably your belt tensioner... or idler pulley. Either one can make that noise.... Just take the pulley off, clean it, and put some grease in the bearing....
Other than that, I wouldn't know. Hope that helps...
cowboydan
if you go off road alot, mud tends to get into the tensioner and it gets chewed, same goes for the alt. might need to but an new one all together
Wihill
