Yo Dewman69,
I will try to move this to the 80-96 Ford Bronco Tech Support section for better visibility. So far, I have failed twice.
Try a Self Test for Diagnostic Trouble Codes (DTC)s by my pal, BroncoJoe19 @
http://broncozone.com/topic/25114-check-engine-light-goes-on-and-off/?p=131701
A helper should assist you.
Do test 2 or 3 tines to ensure accuracy.
Ask local mom & pop parts stores if they can loan you a code scanner. Some do with refundable deposit.
Some basics;
Heat the engine up.
Do KOEO test First
KOEO
KOER
Was IAC Valve (aka Idle Air Bypass (IAB)) checked and it and it's passageways cleaned under the throttle body? Here is a test and overview @
http://www.fuelinjectedford.com/page39.html
Location pic in an 88 5.8
Source: by Travis L (kemicalburns)
Assuming ita C6 automatic transmission. Check vacuum line to the C6 transmission's, (if equipped) vacuum modulator at rear of tranny on passenger's side.
Pull the vacuum line off the modulator. If fluid comes out of the vacuum line your modulator needs to be replaced. Ensure there is ~15-20 in-Hg vacuum at the line from the intake vacuum tree.
See my vacuum leak test in post #20 @
http://broncozone.com/topic/23994-90-58l-getting-continuous-code-33-and-running-code-44/?p=125535
Air filter, is it relatively clean?
Air inlet atop radiator support to filter box and to throttle body; look for obstruction; damaged tubing.
Fuel quality; Oxidized fuel often turns darker over time and may even smell sour. You can check stored gasoline by pouring some into a clear glass container and comparing it side-by-side with known fresh gasoline. If your old sample looks noticeably darker than the fresh gas, you have strong evidence the gas has gone bad.
Electrical connectors; inspect at coil, firewall, PCM, etc. especially those with broken locking tabs.
