MonsterTrukz7
- Joined
- Dec 14, 2004
- Messages
- 5
- Reaction score
- 0
I have a 1987 Bronco with a 351W that is all stock. I am having some carb issues. When shut off, the carb percilates fuel (fuel from the carb drips into the hot intake manifold and evaporates). I get horrible gas miliege, about 8 mpg, i know this is common with broncos though. The worst of the problems is on start up. After having to pump the gas quite a few times to get it started, it will run on high idle just fine to warm up, once i hit the gas to drive away it kicks down as it should. but when stopped at stop lights when the engine is still cold, it will just die. i have to put it in nuetral and put my foot on the gas to keep the rmp's above 1000 to let it warm up more and keep it running. any suggestions as to how to solve this problem? i have been thinking about switching carbs to an edelbrock but i dont know if this is really wise. if i do, i have a feeling that none of the smog emission lines will hook onto the new carb. if anyone has some insight on my issue please let me know. thanks!
