86 Bindage Problem
redneckpunk
Hopkins michigan
I have a 1986 bronco eddie bauer edition when i went to back up to a trailer
today i felt a wierd bindage problem it felt like something was rubbing the tires but
when i checked nothing was wrong but when i pulled forward then back it cleared
up when i first got the truck i checked the diffs the rear was totally empty could this be the problem or something else help me please. :wacko:
ron753
pull the brake drumes on both sides look to see if the axle seals are leaking
if they are that will cause a problem, you should replace the seals and clean the springs and other hardware that hold the brakes on and replace the brake shoes
redneckpunk
redneckpunk
Hopkins michigan
I did notice that the wheel cylinder on the drivers side was leaking but not much else when i drove it today there was no problem but i know the problem did not go away but it still is a mystery
Kingdalt777
