84 bronco engine help!
I have a 84 bronco full size 4wd 351 four barell holley, and I just finished puting in an oil seal in the transfer case and now after letting it sit for a month it is not running right it starts if I pump the pedal and then it will kep runing till the choke plate lifts off. Then I have to hold the gas other wise it dies, it has fresh fuel I just rebuilt the carb like four months ago and checked the fuel filter today. please help!!!
Right, I'd go thru the adjustment proceedure again. Here is a great document on Holley carbs that you might want to read. It will realy increase your understanding of Holleys and how they work. http://www.bob2000.com/carb.htm
Ford644
