74 Bronco tank small vent lines for Emmissions
Broncoholics
Broncoholics
Washington State
My new 74 has the vented aux tank but the rear doesn't have any connections for small airlines. Could be that the aux tank is a 74 and the rear is from an older Bronco before the vent lines. The 4 lines are still in place under the body and come up into the driverside rear fenderwell. All are capped off instead of going into a expansion tank and off to a charcol canister in the engine bay.
Has anyone had luck by capping off these air lines and using vented gas caps instead?
My 68 has never had a problem with vapor lock or any other issues not having vents lines. Should I go to a junk yard and get a newer style expansion tank and charcol canister to help this problem or is it not needed? I will not be connecting the charcol canister to the air filter either so it seems worthless.
What are all you doing with the lines? I fugure to seal them off at the tank or bring up some airlines up high to vent but in a roll over I'd spill gas everywhere.
27124[/snapback]
Hay, none of this.....NO "rolling over"...! :)) :))
My '66 filler neck has the vent tube attached...with the hose paralleling the "fill hose", right back to the tank.
This should work for you.....& I agree, I see no need for all that other "gobbley-****"
Of the newer EB's I've had..... none had any of the vapor lines hooked up. :closedeyes:
79' Buckin Bronco
