5.8 Exhaust????
92broncomann
Coolidge, Arizona
OK. I Recently picked up some stock Lightning Headers off a 95 for a slim $60..... :D /emoticons/[email protected] 2x" width="20" height="20" />
First off I have a 92 Bronco, with a 351w all stock except a 2" lift up front.
I have a few questions about fitting these in.
1) Are these headers a stock replacement to the exhaust manifolds that are currently on the bronco??(I know ill have to fab up and tap a hole in the front of the passenger side header for the preheat on the throttle body)
2)If they are stock replacements will i have to customize my exhaust or will it just bolt up the same way/current locations??
3) Is there dual Cats on my bronco or is the first on just a collector followed by a single cat?? and if i go with true dual exhaust how does one set up cats on it??
Thanks Alot
Without a picture of what you are talking about, I assume that both manifolds are connected in a Y pipe and then enter the first Cat followed by an Air pipe entry followed by a second Cat. If that is the arrangement, they are two Cats and they serve the same Cat function as a single Cat with the air pipe entering at the center of the cat.
