4WD Clicks But Won't Shift
Rusty Tail
My 4WD wouldn't work last winter so I looked into it this summer. The motor/Actuator assembly won't run reliably from the computer or from the battery when directly connected (org & Ylw wires). I am looking at buying a new actuator, however, the speed sensor wires are going to have to come out of the connector to un-tether the assembly from the vehicle. Has anyone ever removed the locking tab and pins from the connector -or- can you point me to the correct article that discusses the process in detail. Are any special tools required?
Thanks in advance for your help.
Karl
'89 FS
302 w/TFI Mod
BW1356 Push Button Shift
Mile Marker Manual Hubs
Interior: Beautiful
Exterior: Custom Rust Job
yo Rusty!
Here ya go;
Disconnect connector by depressing tab on back & slide downward.
1356 Electric Shift Motor Replacement in a 90 Source: by Casey.can.do at Ford Bronco Zone Forums
1356 Electric Shift Speed Sensor Replacement Information & in an 89; "Problem: 4wheel LOW was not working. I only got the blinking LOW light when I selected it. Sometimes it would work, but rarely, and without warning. The bigger problem would be when I would try to disengage it and it would not work. Then I'm stuck in LOW. 4 HIGH worked fine. Lo and Behold my speed sensor was showing about 5 megaohms. I grabbed one from a junkyard and it measured 283 ohms. Swapped them out and it works beautifully! Free fix, and it took about 45 minutes to remove the yoke, tail housing, and solder/splice/heat shrink the new sensor in place. I attached a picture of what the sensor looks like when it's out. BTW the sensor I got from the junkyard came out of a Bronco 2 I think...or maybe a Ranger. I forget, but I kinda took a gamble. It looked the same, and had the same color wires. Either way, it only had one bracket holding it in place, instead of a Bronco/F series BW1356 that requires the removal of part of the transfer case. It's much easier to get when you're in a junkyard..."
Source: by kf4amu (Will H, The Beast)
Four Wheel Drive (4X4) General Information, Operation & Troubleshooting TSB 92-1-8 for Bronco, F Series & Ranger (COMPLETE); Includes Electric Shift On The Fly (ESOF) Troubleshooting & Hub Operation; same for 87-96; exc for that in 87; power from Fuse 6 (15 amp) to "ELECT SHIFT CONTROL MOD" WHT-PPL and CB 12 (30amp) to "ELECT SHIFT CONTROL MOD" BLK-WHT; SEE A7 and A8 in the 4x4 diagram, it shows those two wires BLK-WHT as BK/W from SHIFT MODULE to P1 BATTY and and WHT-PPL as W/P to P2 Source: by Ford via Chilton
Ford644
