4" Lift Kit 95 Bronco
95Bronco
Hello i just got back from 4 wheel parts, i what to lift my 95 bronco 4" they also said that i need some rim and tires 15 x 8 with 33" x 12.5 is this a good tire combo or should i get 15 x 10 rim and if so will they stick-out to much ?
thanks guys
custom_78
San Diego, CA
YUou can use either a 15x 8 or 15x 10 wheel with a 12.50 wide tire. It will give you more clearance for offroadind and yes it will stick out more. Only an inch more with the same backspacing
As a general guideline, use the 15x8 or narrow rims for mud, and the 15x10's for sand, dirt or rocks. You won't have as much sidewall bulge with the wider rims. I split the difference, went with 15x9" rims for my 35's that only see mud.
J
Juice (not logged in)
Guest
there is an advantage to a narower rim though. you can run a lower psi without beadlocks, and have to worry less about loosing a bead. i got a buddy who ran his 12.50 SXs on 7 wide wheels. he ran like 10 psi tops on the trail and hardly ever had problems with beads. were in college so beadlocks are expensive
Wihill
