66Bronk
I just bought a 66' Bronco with a aftermarket 351W engine. I got it home & noticed it was leaking oil from around the distributor & there seems to be a knock in the engine. I know very little about tearing in an engine but I'm not afraid to try. I've worked on other old beaters in the past but never had to dive into the motor....just replace little odds & ends.
Is there a recommended book or manual that you might suggest where I can get started?\
I also want to add power steering & power brakes at a later date. The brakes are terribly soft & I'm just not used that feeling.
Any pitfalls that I need to watch out for?
Thanks!!
Clay
Thanks!!
Clay
