351W block.
sreaminbronco
Dallas
Does anyone know where i can get a 351w block just plain? Im trying to rebuild my whole engine from scratch.
You should be able to get a new short block from either a dealer, auto parts store, or do a Google serch on Short Block. Another source would be from a recycler but make sure you get an engine that is declared good by them and an agreement to take it back. There may be one for sale on this forum, look at parts needed and for sale. Try Blades, he has a lot of stuff he is selling.
I do have a good one but unless your close to Michigan shipping would be ungodly :D /emoticons/biggrin@2x.png 2x" width="20" height="20" />
S
sreaminbronco
Dallas
I found an Iron Eagle block from Dart but the bore is wierd and i cant find anything for it.
What do you mean the bore is weird ? :D /emoticons/biggrin@2x.png 2x" width="20" height="20" />
S
sreaminbronco
Dallas
Read specs and tell me that the way the bore some in isnt wierd.
Vendor Dart
Product Line Dart Iron Eagle Ford Small Blocks
Engine Block Style Aftermarket
Deck Height (in) 9.500
[SIZE=16pt]Cylinder Bore as Shipped 4.125 in. [/SIZE]
Maximum Cylinder Bore Diameter 4.185 in.
Engine Block Material Cast iron
Engine Block Weight (lbs) 195
Main Bolt Style 4-bolt
Main Caps Included Yes
Main Cap Material Steel billet
Main Cap Fasteners Included Yes
Main Bearings Included No
Rear Main Seal Style 2-piece
Finished Cylinder Bores Yes
Raised Cam Location No
Cam Bearings Included Yes
Freeze Plugs Included Yes
Quantity Sold individually.
Notes (Not Specified)
That bore spec tells you what it is shipped as and themax you can increase it.
WOW thats quite the oversize . I think for your usage id stay away from that one sometimes when the cylinder walls get that thin motors tend to run hotter definately dont need that in a 4X4 . I would check with local scrap yards theyve got to have a 351W around somewhere they were used in a ton of stuff and I think Ive seen them date back to 1969 . :D /emoticons/biggrin@2x.png 2x" width="20" height="20" />
If you get a recycled 351W, stay away from the 75 - 84 blocks. They suffered a lot from cracking and very poor casting workmanship. Pre 75 and the post 84 roller blocks are the best to use.
If you get this block, be carefull going the limit with boring, the heating problem Blades is talking about could also cause it to crack. All the material I have suggests stying at .03 over.
A stock or standard bore 351W is 4.000 inches a 30 over block as Seabronc is suggesting would be 4.030 the block your looking at is 4.125 thats 4 times the recomended bore size, thats an extra 1/8 inch in bore size dosnt seem like much but when you think that the cylinder wall is probably around 3/8 of an inch thick and by boreing it that much your cutting its size by a third that is a very big deal . Again I would stay away from that block its for drag racers that run down the line for 10 seconds and get shut off not for a motor that is getting worked very hard in sand or mud for hours on end . :D /emoticons/biggrin@2x.png 2x" width="20" height="20" />
figjeti
