The front cover seal was broken so I pulled it and replaced the stretched timing chain and sprocket.
When installing the front cover don't use the rubber piece on the oil pan or the gaskets, use Permatex Right Stuff for everything, I tried the gaskets first time and they leaked.
I also used a repair sleeve and new crank seal.
I used some short bolts where the WP goes and let the front cover set overnight, then installed the WP yesterday.
Today I filled it with antifreeze, and fired it up, no leaks.
