I have 33 x 12.5's for my 83, and they do not rub except for the radius arms on full turns. I seems to have a lot to do with suspension condition, lift, setback on wheels, and the width of the wheel the tire is mounted on. Soon some trucks, there is no problem and on others you got to do some additional work.
The manufacturer warranty is voided if you mount them on wheels that are narrower than 8.5 inches. Stock wheels for the 80's were around 7 inches and if you stuff them on a stock wheel, the profile wil be higher. Also, if you stuff them on the stock wheels, which can be done, you void the manufacturer warranty and if you pop a bead resulting in a serious accident, you are on your own, (just had to add that 0
). The wheel range specified by all manufacturers for 33x 12.5 x 15's is 8.5 - 11 inches with a 10 inch rim used to get the advertised dimentions.
A quote from the tire rack,
"The measuring rim width is the industry standardized rim width upon which the tire must be mounted in order to confirm it meets its dimensional targets. Because the width of the rim will influence the width of the tire, a standard rim width for every tire size is assigned and must be used. This standardized measuring rim width allows all of the tires produced around the world to meet the same dimensional standards and therefore, be equivalent with regards to their physical size. The measuring rim width is sometimes referred to as the tire's "design rim width"."
Another thing to think about when going to 33's is the fact that you will probably have to change your differential gear ratio. If you don't, you will probably make the truck into a power DOG. You can see a chart in the Jeff's Bronco Graveyard 80 and up catalog that is used to help select the right gear ratios based on tire size. See page 30.
Good luck on your choice of tires,
