2006 Resolutions
Paul91
HAPPY NEW YEAR Y'ALL!
Ok heres what I am thinking about doing to the Bronco before the Dune Season Begins. Please leave me any comments and ideas. If something worked great for you or if it did not please let me know.
3" Body Lift
I want to go with the body lift instead of a suspension lift becasue I do not want to mess with the frontend geometry. My goal is to get in 35" tires. The only rust I have is on the fenders, so trimming them is not a problem, **** I want to. Know of any good complete kits out there? I think that I will have to lengthen the gas fill tube, but what about the trans linkage and steering column? Anything else that I will have to address in doing the body lift?
35" x 12.50 x 15 BFG All-Terrains on Rock Crawler Series 97 Black 15 x10 Rims
I love these tires. I had thought about going to 14.50 width on 12 wide rims, but think that may cause handling issues on the road.
Custom exhaust
Ok, need some help with this one. I, as most guys do, want to get the most out of the motor. I think this is the easiest way to do that to begin with. My initial thought is headers and a true dual exhaust. I would like to have the pipes dump out the read passenger side behind the rear wheel. I want it to sound tough, not loud. The questions are, do I want long or short tube headers? What do I have to be concerned about sensor-wise for the computer controls? What diamaeter tubes should I run? Any tips about manufactures or ways that have worked for you?
Thanks for any input. I look forward to hearing your ideas.
Ford644
