George Coleman
- Joined
- Mar 28, 2008
- Messages
- 58
- Reaction score
- 8
1996 Bronco 5.8 Can the security system that shuts down all the power be disable for good I am having big problems with it when I started back using my keyless remote?
These little electric things is why I stay away from newer vehicles. I like the older stuff that is more simple and you can see things alot better.Remote starts can be goofy.
Does it turn over at all?
So some of the things that can prohibit remote start,
bad hood switch? (I usually never hook them up) Just unhook it for testing.
Stepping on the brake pedal will usually shut off the remote start, so something like a broken and shorted filament in a tail light can prevent the remote start process.
Then most of the installers do a really crappy job so you could have a loose connection in one of the wires in the ignition circuit.
I,d run down that clicking sound. It might be your answer--like a bad connection or relay that needs the terminals cleaned or grounded. Bad connection on grounds cause alot of problems and I,d start checking as many grounds and cleaning them good for a start.When this happens there is nothing no power at all it is dead. What i do not get is the clicking sound from behind the dash and nothing works at all?? No remote start
