1990 bronco
Jferris83
I have a 1990 bronco and I turn the key to lower the rear window but get nothin....even hitting the buttons on the dash and still nothin, u think its the motor? I am new to this site. I'm loving it so far.
The easiest way to tell is to jumper the motor leads using a 12V battery or a 12 to 14.4 volt cordless drill battery. Open the access panel and find the motor leads running along the bottom edge of the panel. If that makes it work, you have a connection problem. Before doing that, try pushing in on the driver side of the door while operating the tail gate switch, sometimes it is just that you need to adjust the striker.
J
Jferris83
Ok, I took it apart and the lock on the back of the tailgate has nothin hooked up to it. When u put the key in ait just keeps turning. Plus when I use the controls on the dash the motor doesn't run or anything.
Sounds like someone ripped the wiring out. The motor leads are along the bottom edge of the access panel. if you slide your hand along the leads you should find a connector you can take apart to jumper the motor or just pierce the leads. Switching the polarity on the leads will change the direction of the motor. Check in the bottom under the switch to see if the missing switch hardware is is there. The switch hardware should be attached to leads near the key tumbler position.
Tail gate motor circuit diagram attached.
mindy
