1990 bronco 5.0 Bauer - A/C
Trinidadwho
West Hills, CA
Can I completely pull the A/C system from a 1990 bronco 5.0 XLT and install it in a 1990 bronco 5.0 eddie bauer?
Rons beast
Hey Trinidad, Welcome.
My answer would be ...yes... the EB is a trim package, everything should fit. However be aware you will need other things, like the bigger rad that should come with the Ac vehicle, and the controls, air distribution box may need changed, and other little pieces.
It may be easier to go to an aftermarket AC system.
Good Luck
yo T,
The entire A/C refrigerant system can be removed as a unit from all 80-96 gasoline (& probably diesel) F-series & Broncos without much trouble. The fan & shroud have to come out so the radiator can tilted back, and the belt has to come off, of course. But no coolant, refrigerant, or other fluid lines have to be opened..."
Removal Instructions & pics in a 95 5.0
Source: by just_a_warning (Gronco) at http://www.supermotors.net/registry/24908/79955
here are the std removal instructions by an aftermarket company that sells the AC bypass pulley
