!!!!1973 eb specs help!!!
Siscokid34
hey guys, im looking at a 1973 eb
it "should" have for a stock set up......
dana 44 frt
dana 30 t-case
ford 9in rear
correct?
how do you tell if it has the D-44 set up?? numbers, markings?
and the 9in unbolts from the front and the rear housing "pumpkin" is just larger right? any other give aways?????
thanks for the help
S
Siscokid34
also, it already has the power brake set up for a drum. So my question is.... there any frt disc set up i could use from a junkyard rig? instead of spending big $$$
any info would help thanks
hey guys, im looking at a 1973 eb it "should" have for a stock set up......
dana 44 frt
dana 30 t-case
ford 9in rear
correct?
thanks for the help
STLKIKN
Calgary Alberta
Dana 44 has ball joints (in almost all cases.. there were very, very few king pin 44s built)
the t case should be a Dana 20
The rear diff will be a 9", the HD (larger centered housings) weren't used until 76/77.
A chev disc brake conversion will work, you'll need a disc/ drum master, and proportioning valve.
Dana 44 diff cover will look like this...
S
Siscokid34
Dana 44 has ball joints (in almost all cases.. there were very, very few king pin 44s built)the t case should be a Dana 20
thanks, but what year chevy truck do i need, and there isnt a ford F-series that will swap out??
Similar threads
T
Replies
Views
1K
Top stories on BroncoZone.com
T
T
Replies
Views
1K
T
T
Replies
Views
1K
T
T
Replies
Views
2K
T
T
Replies
Views
2K
T
Virgil3rd
