hey guys im working on a 73 bronco when i started it it had 3 fuel tanks i did away with all but the rear one it has 2 small lines on the drivers side which i know run to the jug in the 1/4 panel on drivers side on back of tank there is two lines i know the one runs to the fuel pump the orther line runs along drivers side frame till about middle of the truck then turns towards pass side im thinking it went to the tank under pass side do i need this line if so where could i run it any diagrams or help id be greatful thank you
