Upgrade Your Bronco with Morimoto XB LED Headlights with Amber DRL
CARiD
Cranbury, NJ
Nothing compares to the thrill of an off-road trail ride or the exhilaration of nighttime driving on the highway. However, statistically, nighttime driving presents one of the greatest challenges, as poor illumination leads to reduced visibility and slower reaction times. CARiD is here with an advanced lighting upgrade from Morimoto, designed to deliver exceptional illumination that far surpasses traditional OE headlights for your 2025 Ford Bronco.
Morimoto XB Series headlights are a testament to modern engineering. Unlike conventional turn signals that flash all at once, these feature advanced Kuria Optic Bi-LED technology, creating a smooth, gradual fading effect. The LED segments illuminate in a fluid, sequential motion, activating progressively from the inner edge outward. Powerful and long-lasting LEDs provide a precise beam pattern with outstanding width and intensity, ensuring superior visibility in any driving condition. Additionally, Morimoto optics incorporate integrated vertical and lateral adjusters and meet or exceed SAE, DOT, and FMVSS108 regulations.
Morimoto® - XB™ Black Projector LED Headlights with Amber DRL
Fits: 2021-2025 Ford Bronco;
Includes:
  • (2) Headlights;
  • LINbus Wiring Harness;
  • DRL Fuse Tap;
Specifications:
  • Light type Kuria Optic Bi-LED;
  • Light color white (low, high beam), amber (DRL, turn signal);
  • Functions low/high beam, DRL, turn signal;
  • Lens material UV-resistant polycarbonate;
  • Housing material ABS plastic;
  • Connector Ford multi-pin OEM;
Built for long-lasting durability, each set features UV-coated, wear-resistant lenses and rugged housing that maintain their like-new appearance even after years of use.
Morimoto XB Series lights are designed to match the dimensions and overall design of OE headlights, ensuring a perfect fit. Installation is straightforward with plug-and-play connectors, though grille removal is required. Each assembly comes complete with all necessary connectors, rubber seals, and pigtails, guaranteeing error-free operation with no flickering, hyper-flashing, or radio interference.
CARiD
CARiD
Cranbury, NJ
Whether it's a nighttime highway drive or navigating off-road terrain after dark, upgrading your lighting is essential for safety and visibility.
The newly released XB™ Black Projector LED Headlights with Amber DRL by Morimoto are engineered for high-performance illumination, delivering a powerful, focused beam to enhance visibility and ensure confident driving in any conditions.
To explore the full range of Morimoto lighting solutions suitable for your Ford, follow the link below:
https://www.carid.com/morimoto/
