Bronco Build
Rookie
I just purchased a 76 Bronco. My goal is to build one of the baddest off road Broncos around. I'v Been looking at suspension kits, James Duff Monster kit W/ the long travel suspension. Does Any body have any suggestions on what kind of suspension I should Buy. I'm looking for a very soft ride, but that can handle some hard shots.
S_bolt19
Colorado
buy the Cage Offroad kit. Duff is the 1.1 version of the Cage equipment because it was actually designed by Cage (he used to work for JD then went out on his own). Then get the extended rad. arms from him.
www.cageoffroad.com
If you want to go extreme, then do a coil over conversion if you have the time, money & inclination. Change axles to D60s with 5.88 gears, lock it both ends, Atlas II xfer case.....the list can go on and on. You just gotta figure out where you want to draw the line :) /emoticons/[email protected] 2x" width="20" height="20" />
By the way, welcome to the board.
Broncoholics
Broncoholics
Washington State
The Cage suspension is very nice but expensive for the arms. Its what I run now but I always had fun with a std 3.5" lift and a wristed arm also. Is it flex you're after? Bigger tires? Look into full width axles. How bad ass do you wanna go? I'd recomment keeping the looks of the Bronco but here's some ideas to kick around...
R
Rookie
Thanks for the pics. The full size axles look *******, but I would like to keep the body of the bronco as stock as possible, and still get the most performance possible. Maybe a 5.5" Cage system w/ long travel what do you think.
Broncoholics
Broncoholics
Washington State
Yeah go with Cage then! I just finished my D60, D70 stretched wheel base with Cage 5.5" lift. Its *******! I'll have photos one of these days...
R
Rookie
I will Be hunting out of it most the time, But I still want the smooth ride and the ability to 4x4 when I want. What kit do you have on your bronco in the picture.
KJ'84
