my rear window broke and it was easy to remove because i just vauumed up the million pieces it shattered into. I am buying a new window this week how do i install it and how easy is it. the shop thats selling it wants to charge $100 for them to install it does anyone have a picture or a good site for me to go to so i don't screw this new one up on the install?
Page 1 of 1
Tailgate Window Installing a new one
#3
Posted 12 September 2006 - 03:20 PM
If the $100 includes the price of the glass, it's a deal. Have them do it. Otherwise, depending on if the guides are already bolted on the bottom of the new glass, it can go one of a few ways. The easiest is to remove the guides that are pop-riveted into the glass at bottom. I have found it is easier to drill the rivets out...some people use a cut-off wheel. I went through a few cut-off disks on just a couple of the rivets. The rivet size is 3/16" I think. So, drill straight and carefully with a smaller bit. Then, CAREFULLY slide glass into tailgate (make sure you have the regulator arms all the way down first). Once in, and you may need a friend to help secure the glass while working, either bolt or pop rivet the guides back on the bottom. Then hook your arms up. Good to go.
Snowman74
Snowman74
Snowman74
1987 Ford Bronco XLT (full size)
302 EFI (speed density)
4 WD, Manual Lockers, 4 Speed Borg-Warner T18 manual tranny
Headers, Flowmasters, CAT-Less Exhaust
Bridgestone Dueler A/T Revos 235/75R15
#4
Posted 13 September 2006 - 02:08 AM
Glass Replacement, Tailgate by RFR (Mark B at rfr.htmlplanet.com) - web site is gone, but this is a Cached version until Mark can est. a new site via web.archive.org
http://web.archive.o...nal_page07.html pics are gone tho;
Replacement (many photos) by Dustin S http://ylobronc.user...g/tailgate.html
and Replacement, Glass w/rivet removal pics in an 86 by Ryan M (Fireguy50) at SuperMotors.net
http://www.supermoto...stry/1501/14806
See our Big Bronco Technical/Mods, Parts Sources, Technical Service Bulletins, & Vehicle Classified/General Info Links site
96 Bronco, E4OD, Man Xfer Case & Hubs
Bless All Who Serve
Bless All Who Serve
Page 1 of 1
Sign In
Register
Help
Add Reply
MultiQuote
