briarrabbitt
Hey guys, I've got another question I'm hoping someone can answer. I just changed the oil in my 88 Bronco II last weekend and everything was running good over the weekend until I took it to work that Monday. After parking it and going inside I happened to look out the window and I could see on helluva puddle of oil underneath the darn thing. After crawling around underneath it for an hour I finally located where it is dripping from but I don't know what it is. I think it is an oil level sensor. It's located on the drivers side of the engine right above the oil pan towards the front of the block. It's just a little plug with a wire attached to the top of it but boy does it leak oil! Searching google and these forums I can't find anything about an oil level sensor in an 88 Bronco 2.9L. I can find a lot of oilpans with the oil level sensor hole in them but not just an oil level sensor. Does this thing have an oil level sensor or am I all wet?
