Transfer case sounds
bigwheel6
I have 45,000 on a 99 XLT. I'm in AWD 99%+. Lately I've been getting a kind of scraping and roaring sound when accelerating at 40 to 60 mph. The sound will stop if I put it in 4WD. Has anyone else had any transfer case problems with the AWD? Is this a sound of aging or a death rattle. I don't want to go to a Ford dealer shop or transmission shop for "exploratory" work if I can avoid it.
Errofelon
Belgium
Only in 4wd when i get on the gas a little, what seems to be the transfer case makes a loud POP it sounds alot like the chain slipping over the sprockets.
its only in 4wd the truck drives amazing in 2wd
any ideas?
69bronc347
southern michigan
do your self a favor and check the tread depth on your tires, if the depth on your tires has a huge difference front to rear, that is more likely the cause of your problem, its like having 2 different size tires
RezBarron
