I'm in the process of removing the rear quarters on my 91 and need some input on how to remove a certain portion of them.
On the inside there is an area where the quarter is on the inside of an interior panel. I'm not sure if I need to cut the spot welds here or if the panel simply slips out from behind it. My guess is I have to cut the spot welds before moving on to getting it out. Also, on the outside here the where the quarter panel seem meets the top portion of the cab...are there spot welds here that will have to be drilled out? I've attached 2 pics showing what I'm talking about.
Thanks for any input!
