Jump to content
Was a bench seat a option
2 replies to this topic
#1 Jeff Ogden
Jeff Ogden
    Bronco Maniac
  • Members
  • PipPipPipPipPip
  • 170 posts
  • Gender:Male
  • Interests:old cars ans cold beer
  • Favorite Bronco Year?:1978
Posted 28 November 2017 - 05:31 AM
I removed the rear seat on my 88 and installed a XLT front bench,I was hoping that the seat would sit in 4 of the existing holes but not such luck but ended up finding that there were holes in the floor for a bench seat with plugs in them. I have put carpet in trucks before and do not remember seeing extra holes and never have seen one with a bench seat before.
88 Bronco Eddie Bauer, 302 and AOD and its 2wd now
#2 miesk5
  • Moderators
  • PipPipPipPipPipPipPipPip
  • 7302 posts
  • Gender:Male
  • Favorite Bronco Year?:1996
Posted 28 November 2017 - 10:40 AM
Yo Jeff,
Cloth & Vinyl Front Bench Optional in 88 Bronco Custom & XLT, NA in Eddie Bauer
In 1988 Bronco Dealer Brochure, partial @ http://broncozone.co...re/#entry119365
Mount Info; "...The Broncos come equipped with both mounting capabilities, Bench and buckets. I just did this very swap from buckets to bench out of a 93 F150 XLT at the junk yard, it came with power dual lumbar, fold down arm rest, and dual cup holders for $45.00 in new condition. The mounting points for the bench are there under the carpet and they are plugged with rubber grommets. You do not have to tapped the holes either, the bolts that hold the buckets in place are self tapping, and they go in rather easy. The mounting points are made up of metal sleeves that are not threaded if never used and the self tapping bolts are easy to install. Just swap over the rubber plugs from the bench locations to the bucket locations and you are set. You also use the same seat belt locations and you are going to have to use the seat belts from the bench. The belt plastic sleeves are molded differently, and will not point in the right direction. Everything is plug and play, down to the lumbar..."
Source: by Camo Horse
96 XL 5.0 E4OD, Manual BW 1356, manual hubs. See my partially recovered Bronco site. I need to clean up dead links & add many more. Thanks you Mr, Schwim! http://schwimserver5.com/?index=1128
THANKS to ALL WHO SERVE!
#3 miesk5
  • Moderators
  • 7302 posts
  • Gender:Male
Posted 28 November 2017 - 01:02 PM
Complete 1988 Bronco Dealer Brochure @ http://broncozone.co...ealer-brochure/
Reply to this topic
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
