Bronco Paperwork
I found this,
Under the rear carpet of the Bronco. From what I understand, this is the build sheet for my Bronco that would of followed it around as it was being built to make sure it got all the correct features. I have have it in a photo frame to protect it from damage.
Thought I would share.
Yo Skitter,
Yes, it's referred to as the Build Sheet.  I have tried for years to obtain all the codes to no avail, however some categories are obvious.
 Build Sheet Location Synopsis; Locations vary because it depended upon who threw it in the Bronco on the production line vs. those who took time to place it same place for 18 years: "...under the driver's or passenger side carpet, in the fiberglass top hidden behind the rear trim piece, driver's side in a 79 by Ziggy; was under the rubber mat under the driver's seat in a 78 by Scoop; under my carpet on the right side in the back in a 92 by M. Cardholder; under the carpet directly behind the front passenger seat, Under the cardboard spacer sheet/heat shield in an 88 by Dustball; under the drivers side of your front seat between the seat springs and the cushion in an 86 F 150 by Hoxviii; underneath the carpet under the drivers seat and another in the back end underneath the carpet in an 88 by Xris; Ive found them in the back seat front seat Passenger floor Board and head liner. Gently feel your back seat for paper under the vinyl. Same with the back and then under the seats. Possibly under passenger carpeting rubber mat in a 78 by F1rocco; under my rear deck carpet and padding, taped to the bed in an 89 by Buckin' 89Bronco...";
Up to just a few years ago,  Ford would provide upon request this [SIZE=23.9997px]free-of-charge Ford 999 Report;[/SIZE]
 Build Sheet Information (Ford 999 Report) in an 88 5.0
Source: by Jem270
The Ford bean counters then decided to sell that info to HELMs in 2011.
 Helms charged $17.00 for a "Basic" Sheet and $48.00 for a "Deluxe" sheet. Helms is Ford's Official Publisher for Ford EVTMs, Owner Manuals, Wiring Diagrams, etc. Miesk5 Note on 30 AUG 2011 called Ford @ 1-800-392-3673 & Jeff said all have been transferred to Helms.
Somehow Marti Autoworks took over; "...privleged licensee (contract #5012) to Ford Motor Company's entire production database for the 1967-2012 model years.
Here is a sample invoice;
Or the familiar, http://www.martiauto.com/martireports.cfm
These appear similar to the previously Free 999 report.
