hello from Albuquerque NM
Welcome to the ZONE!
Would like to know more about how you mounted that roof carrier to your Bronco.
Yo nm95bronco,
Our son has that same LED light bar on his H3, but mounted on the rear of his home-made roof rack for surf fishing.  It is awesomely bright!
Here is the 1995 Bronco Dealer Brochure by Ford via me @ http://www.supermotors.net/registry/3549/79188-2
Was cruise control, if equipped, recall work for your 95 completed?  Call local dealer with VIN.
To post a pic from your PC, TABLET, etc., just below the reply box in lower right corner, click More Reply Options
Screen will change
See Attach files
pick out the pic
Click Attach This File
or click, Try our advanced uploader (requires Flash 9)
http://www.irfanview.com is a good free image resizer.
• Post any TECH questions in a new thread in 80-96 Ford Bronco Tech Support section & keep it limited to one issue. Mainly so that old farts such as I don't get confused.
To show off your 95, such as any build-up or modifications post in 80-96 Ford Bronco section.
Here are some wiring diagrams (partial, 86 through 96) and Technical Service Bulletins, (80 through 96) @ http://www.revbase.com/BBBMotor/Wd
Just register for free.
cya in the forums!
Sgariffo
