Jump to content
Does this look right?
3 replies to this topic
#1 jonathankallen
jonathankallen
    Where's My Hammer!?!
  • Members
  • Pip
  • 7 posts
  • Favorite Bronco Year?:1990
Posted 26 September 2017 - 07:18 PM
I've fixed the headlight assemblies, driver's side door switch and window regulator, got the transmission dipstick tub sealed, and now I'm working on the radio.  The radio (and a/c-heater unit) is not working at all.  What's your thoughts from this wiring that could be causing the problem?  Do the bigger red and yellow wires go to the air unit?  What's your thoughts?
1990 Bronco Eddie Bauer Edition-5.0-automatic-electric shift-automatic
#2 miesk5
  • Moderators
  • PipPipPipPipPipPipPipPip
  • 7310 posts
  • Gender:Male
  • Favorite Bronco Year?:1996
Posted 27 September 2017 - 03:38 AM
Looks like a bad attempt to do something by a previous owner.  But I can't see the colors well.
Best is to use these wiring diagrams to match the wires up.
Radio Wiring Diagram in a 90
Source: by Seattle FSB (SeSeattleFSB)
and
a/c-heater unit in a 90 by Seattle FSB (SeSeattleFSB)
Ford wire color code abbreviation chart
BK Black
BL Blue
BR Brown
DB dark Blue
DG Dark Green
GN Green
GY Grey
LB Light Blue
LG Light Green
N Natural
O Orange
P Purple
PK Pink
R Red
T Tan
V Violet
W White
Y Yellow
Where two colors are shown for a wire, the first color is the basic color of the wire. The second color is the stripe marking. For example: BR/O is a brown wire with an orange stripe.
GL!
96 XL 5.0 E4OD, Manual BW 1356, manual hubs. See my partially recovered Bronco site. I need to clean up dead links & add many more. Thanks you Mr, Schwim! http://schwimserver5.com/?index=1128
THANKS to ALL WHO SERVE!
#3 Skitter302
    Bronco Pimp
  • Moderators
  • 295 posts
  • Gender:Male
  • Interests:Welding
    Bronco(s)
    Driving
    Racing
    4x4
    Custom Gear
    A/M Parts
  • Favorite Bronco Year?:1993
Posted 27 September 2017 - 09:19 PM
Factory Radio Install and Removal
Radio Wiring .pdf
See if this helps any. Had to Buy a new headunit to get these .pdf(s)
1989 Bronco XLT -- 302in³ EFI 5.0L (4942cc) -- AOD -- Borg Warner 1356 -- Manual Hub(s) -- 31x10.5 R15
1991 Bronco Eddie Bauer ~ 351w EFI 5.8 (5752cc) ~ E4OD ~ BW1356 (Manual) ~ Manual Hub{s} ~ 265/75 r15
Posted Image
#4 jonathankallen
jonathankallen
  • Members
  • Pip
  • 7 posts
Posted 04 October 2017 - 07:04 PM
I'm going to buy a brand new wiring harness from Crutchfield because the one that's in there has been worked over a few times.  Just out of curiosity, what is this smaller clip for coming out of the bigger clip?  there's a smaller clip on each of the bigger clips that were not plugged in to anything (sorry for the not-so-technical words).
Also, I'm getting new speakers and I saw a post on here that said the original rear speakers were 5x7 and that you'd need to get a conversion kit to use 6x8 but a lot of websites like Crutchfield show that you can use 5x7 or 6x8.  What's been your experience Skitter since it seems like you've done this before?  I'm not wanting to make any modifications to the rear speaker cover.
Reply to this topic
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
