E40D Trouble
I'm posting this to stay ahead of he curve and prep my self for what might be coming.
I was working on the Bronco the other day (checking fluids nothing fancy) and I noticed a buzzing noise coming from the transmission. It isnt loud but just enough to be heard while the key is on but the engine is off. From what I gather it is the solenoid pack making the buzzing noise. Currently drive-ability isn't effected and a loss of torque is never felt... but I occasionally get a hard shift from 2nd to 3rd. (never worried about those intermittent hard shift up till this point) I wouldn't be worried about this at all except that, after a 20min drive the transmission pan is hotter the my oil pan. I'm talking about to the touch of the hand noticeably hotter. I can leave my hand on the oil pan for 3-5 sec but the transmission hurts after 1.5sec. I know, not a very technical measurement but y'all get the idea.
My question is should i really worry about it?
or
Option 1: get the solenoid pack replaced?
Option 2: Full transmission rebuild?
Just hoping that I'm over thinking the whole issue and I can just make an adjustment myself and move on.
Yo Skitter,
Has check engine light come om while driving?
Is the Transmission Control Indicator Light & Switch (Overdrive) blinking while driving?
See this 96 Bronco-F-Series Workshop Manual
Section 07-01A: Transmission, Automatic, E4OD
1996 All F-Series and Bronco with E4OD Automatic Transmission Workshop Manual
DIAGNOSIS AND TESTING
http://www.diesel-dave.com/vehic/manual/stj/stj71a24.htm#extract_1037
Look at;
Other Concerns: Transmission Overheating
No extra lights coming on. If some were it would be easy to pin point the problem. Couldn't find any extra info in the link you had. Only if their was a error code would I need to check those circuits.
I know it would be "easy" with those lights on, but I had to ask you.
Here is the info in themlinl I gave you;
Possible Component Reference/Action
257 — ELECTRICAL ROUTINE
Powertrain Control System
Electrical inputs/outputs, vehicle wiring harnesses, powertrain control module, torque converter clutch solenoid
Run On-Board Diagnostics. Refer to Powertrain Control/Emissions Diagnosis Manual for diagnosis. Perform Service Manual Pinpoint Test C using Rotunda Transmission Tester 007-00085 and Cable and Overlay 007-00107 or equivalents as outlined in this section. Service as required. Clear codes, road test and rerun On-Board Diagnostics.
357 — HYDRAULIC/MECHANICAL ROUTINE
Excessive Vehicle or Towing Loads, Severe Vehicle Usage
Refer to the Vehicle Specification Manual for load and GVW/GCW information. Refer to Owner's Manual.
NOTE: If auxiliary cooler is desired, use ONLY Ford original factory equipment installed to factory specifications.
Fluid
Improper level
Condition
Adjust fluid to proper level. Inspect according to instructions under Fluid Condition Check.
Transmission Cooling System
Damaged, blocked, restricted, or improperly installed
Perform Transmission Fluid Cooler Flow Test.
Inspect for damage, restrictions. Service as required.
Vehicle Concerns Causing Engine Overheating
Refer to Engine Condition and Cause charts.
Torque Converter Clutch
Not engaging
See Routine No. 240/340.
Other Concerns: Noise/Vibration — Forward Or Reverse
254 — ELECTRICAL ROUTINE
No Electrical Concerns
354 — HYDRAULIC/MECHANICAL ROUTINE
For Noises/Vibrations that change with engine speed:
Torque converter components
Fluid level (low) pump cavitation
Pump assembly
Engine drive accessories
Transmission oil cooler lines grounding out
Flywheel
Fluid filler tube grounding out
Locate source of disturbance. Service as required.
For Noise/Vibrations that change with vehicle speed:
Engine mounts
Loose, damaged
Driveline concerns
U-joints
Rear axle assembly
Suspension
Modifications/misalignment
1st gear
One-way clutch, gear set
Friction elements
Torque converter assembly
2nd gear
Intermediate OWC
Friction elements
3rd gear
One-way clutch
Friction elements
4th gear
One-way clutch
Gear set
Friction elements
Reverse
Gear set
Friction elements
Shaft spline fit
Slip yoke, park gear
For specific shifts or torque converter concern, refer to appropriate routines:
No Shift 1-2, Routine 320
No Shift 2-3, Routine 321
No Shift 3-4, Routine 322
No Shift 4-3, Routine 323
No Shift 3-2, Routine 324
No Shift 2-1, Routine 325
No Converter Cycling, Routine 242/342
Other Noises/Vibrations:
Main controls
Valve resonance
Shift cable
Vibration, grounding
Transmission fluid cooler lines or fluid filler tube
I have been trying to solve the issue because all solenoids do work but something from the PCM was off but I couldn't put my finger on it. So here is what I have done to fix this issue. Not saying that this will work for everybody but this is what fixed MY E40D troubles.
To stop the solenoids from buzzing/clicking I had to replace the MAP sensor with a BWD unit from O'reilly. Not only did the new MAP get rid of the noise but it fixed my drivibility issue where the bronco would want to loose power for a tenth of a second every time the throttle open'd from the closed position. And my hunting idle just about went away too. Instead of a idle that fluctuated 200-400rpms. It now fluctuates only 100-200rpms.
But that didn't solve the heat issue. this is one of the crazyest things I have done to solve an issue like this an I wouldn't recommend this to others but I put in a Banks Power ( _LINK_ ) Transcommand. $318 box that honestly isn't isn't that much more impressive over a RadioShack resistor. But it did solve my heat issue.
Sgariffo
