laurentj23
- Joined
- Jul 13, 2017
- Messages
- 5
- Reaction score
- 1
Hey all,
First post here, and I need you guys help before I ended calling a mechanic. I'll do it in cliff notes to make it easier to read.
1.Drove home on the HWY and car just died.
2.Found out that my v belts broke and messed up all the wiring. Yes the wiring is messed up from the previous owner try to hardwire the LED lights etc etc
3.Try to crank it and won't start, start one time with starting fuel (fuel pump issues).
4.Did not hear the fuel pump prime when trying to start the key to acc.
5.Check the relay and there is no power on the relay.
http://easyautodiagnostics.com/ford/...-relay-tests-3
6.CheCk the ECM and relay and there is low voltage coming from the ignition to the pcm.
7.Replaced the broken fusible link, and still has no power to fuel pump relay connector. I was able to hear the fuel pump by jump starting it but now the battery is dead.
8.Recharge the battery, connect everything and now there is no power at all even in the compartment where there usually a buzzing sound when I open the door.
Please help, i wasted 185 Bucks on this guy that claimed that he can fixed it. He rewired it, told me that the circuit breaker is blown, replaced the breaker but still no power.
Thanks.
[SIZE=13.3333px] [/SIZE]
[SIZE=13.3333px]Battery has a good voltage.[/SIZE]
Thanks.
