1982 Full Size Bronco Speedometer Gear NP208
Caxtus
I am rebuilding the NP208 transfer case in my 1982 Bronco. When I opened the case I found the speedometer gear to be chewed up in some areas. Now the problem is that I cannot find a replacement anywhere. All I can find are GM parts which appear to be longer than what came with the Ford variety of NP208s. Any help is appreciated for finding a replacement gear.
I have attached a photo showing the opened case. The gear I am referring to is the blue plastic one on the right.
Yo Caxtus,
They are getting rare.
Contact, because they don't  specify Ford;
https://cobratransmission.com/index.php?main_page=index&cPath=3_2091&sort=20a&page=3&language=en
331997 Speedometer-Gear-quality-Transfer-Case-Parts-Cheap.jpg NP 208, Speedometer Gear
NP 208, Speedometer Gear (18 Tooth, Blue) (14037996) (Out of Stock - 07/01/13)
Contact For Price and Availability
... more info
Contact For Availability
  IPN3-U331997 Speedometer-Gear-quality-Transfer-Case-Parts-Cheap.jpg NP 208, Speedometer Gear
NP208 Speedometer Gear (18 Tooth, Blue) (14037996) (Good-Used)
$14.99
... more info
Contact TCI @
http://www.tciauto.com/tc/contacts/
GL!
