Jump to content
1981 stuck in four high?
19814wd 4hi 2hi bronco hubs 4wd 4x4 2wd stuck
3 replies to this topic
#1 BillDM
BillDM
    Bronco Newbie
  • Members
  • 1 posts
  • Favorite Bronco Year?:1981
Posted 14 June 2017 - 04:54 PM
Hey guys, new to the forum, hoping you guys could shed some light on a current problem I'm having.
I recently bought a 1981 bronco with a 351m.
The truck was running fairly well for the first few months or so before it began to bog down and refused to accelerate after driving for periods of around 30 min or so. I brought it into a local mechanic. They diagnosed the problem and replaced the spark plugs, spark plug wiring, and the ignition coil. When I got the truck back i noticed a nice increase in power, and thought my problems were solved...
But then i noticed the 4x4 indicator on the dash was on and the truck was in four high after driving on dry pavement for about 15 minutes. I stopped the truck, put it in neutral and and attempted to move the transfer case lever up to 2 high. It would move into what seemed like the correct position, but the truck wouldn't move when shifted into drive or reverse, just kept at that higher idle like it does in neutral and revs when the accelerators pressed.
I checked the manual hubs to see if maybe they needed to be moved up into free position, but they were already free. I tried moving in reverse in 4 high, and then shifting into 2 high, but still failed. The manuel hubs were free during the whole situation. Do they need to be locked in order to shift out of 4 high and then released? Do i need to be moving in order to make the transfer? Or do i have some sort of greater issue? Any advice on getting the truck back into 2 high would be greatly appreciated.
Edited by BillDM, 14 June 2017 - 04:59 PM.
#2 miesk5
  • Moderators
  • PipPipPipPipPipPipPipPip
  • 7224 posts
  • Gender:Male
  • Favorite Bronco Year?:1996
Posted 15 June 2017 - 03:13 AM
Yo Bill, Welcome! I assume it's a NP 208. See attachments on diagnosis & fluid level check.
96 XL 5.0 E4OD, Manual BW 1356, manual hubs. See my partially recovered Bronco site. I need to clean up dead links & add many more. Thanks you Mr, Schwim! http://schwimserver5.com/?index=1128
THANKS to ALL WHO SERVE!
#3 miesk5
  • Moderators
  • 7224 posts
  • Gender:Male
Posted 15 June 2017 - 12:01 PM
Yo Bill,
The manual hubs won't cause it to stay in 4 high.
Confirm New Process (NP) 208 @ http://www.blueovalt...nsfer_cases.htm
"I stopped the truck, put it in neutral and and attempted to move the transfer case lever up to 2 high"
You did right.  Believe the instructions are on back of the driver side sun Visor.
208 Parts Break-Out Diagram (PDF version) in an 88 w/out nomenclature
Source: by Dustin S (Dustball, Mellow Yellow, Mr. Laser Boy)
#4 miesk5
  • Moderators
  • 7224 posts
  • Gender:Male
Posted 21 June 2017 - 03:28 AM
Anything new?
Reply to this topic
Also tagged with one or more of these keywords: 19814wd, 4hi, 2hi, bronco, hubs, 4wd, 4x4, 2wd, stuck
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
