Jump to content
No Spark 1975 351w
7 replies to this topic
#1 redfishtony
redfishtony
    It's Only Money, Right?
  • Members
  • PipPipPip
  • 27 posts
  • Gender:Male
Posted 19 May 2017 - 06:55 PM
Ok guys, I'm about ready to throw in the towel. Last week we got the 1969 sport running like a top. New starter, battery, solenoid, ECM,voltage reg,all was good. Then Sunday afternoon lost all spark. The motor is a 1975 351w out of an LTD. I have tried to trace all the wire but it's a mess. It seems when I used my test light with ignition switch on I have power to both side of the coil.this doesn't seem right. Why would it just suddenly stop firing. How about the pickup in the duraspark distributor? Is there a way to test it. They have two wires spliced into the wires at the switch. One is hooked to the green wire and the other is hooked to the red with blue or grey stripped. There got to be some sanity. Thanks for any advice or ideas.
Redfishtony
Thomasville, GA.
69' U152
351W
Mostly Stock
#2 Bully Bob
  • Moderators
  • PipPipPipPipPipPipPipPip
  • 3854 posts
  • Gender:Male
  • Interests:Going nose-to-grill with GIANT Bulls here in the high desert.
    Hence-forth my given C.B. trail handle;
    "Bully Bob"
    Hot women, 4x4'n, flying homebuilts -- or -- a nice Super Cub !
  • Favorite Bronco Year?:6677
Posted 19 May 2017 - 09:36 PM
"...with ignition switch on I have power to both side of the coil.this doesn't seem right."
No, this doesn't seem right. Just a guess., maybe the coil shorted out..??
Electronic ignitions req. certain coils depending on the (ECM) mfgr. of the ignition.
Also, two types. One type is "Halls affect" ---- (can't recall the others callout)
"How about the pickup in the duraspark distributor?"
These can fail but it's pretty rare. Good news, they're inexpensive.
Keep us posted...
---Jeep recovery unit---
1966 "U-13" Roadster...topless, doorless. (with rag top-n-doors)
200 cu.in. I-6 with 250 head.
$30 homemade HEI elect. ignition.
Full roll-cage, front.
70+ MPH cruise---15 MPG
6 EB's (& 11 early Land Cruisers) referbished & sold..
#3 Rons beast
Rons beast
    Supreme Commander
  • Moderators
  • 1543 posts
  • Gender:Male
  • Interests:sleeping, eating, building something, repeat.
  • Favorite Bronco Year?:1996
Posted 20 May 2017 - 04:09 AM
Hey Red,
Connect a test light between the + and - terminals on the coil.  Crank the engine.  The light should flash.
Got a flash= bad coil.
No flash = indicates a breakdown in the primary ignition.
If you have 12 V at the + terminal with the key on then the module is not giving a ground to the coil. (the providing of a ground, then removing it is what "fires" the coil.)
that should come from a green wire.  HOWEVER!  the module gets a ground from a black wire from the distributor. Check that this wire is providing a good ground.
Many off-roaders have spliced in a strong ground direct back to the battery to prevent problems from lack of ground.
Check these wires if intact, suspect your module.
Good Luck
04 Mercedes ML500
00 Linc LS "The Ride"
92 Mercedes 500SL "The Baby"
08 Mercedes SLK "The Wife's"
82 Chevy S10 Custom "The Project"
always changing (Given to my son)
96 Eddie Bauer (The Beast ) Sold
#4 Bully Bob
  • Moderators
  • 3854 posts
  • Gender:Male
    "Bully Bob"
Posted 20 May 2017 - 08:53 AM
Hi Ron..!!
Not to 2nd guess but.., I'm struggling to understand;
"needs to flash but, if it does--- bad coil"..?
"no flash means ---- bad coil"..?
Also on my ignition, key off, no V to the plus side of coil.  Key on, there's a constant 12V
#5 redfishtony
redfishtony
  • Members
  • PipPipPip
  • 27 posts
  • Gender:Male
Posted 20 May 2017 - 06:58 PM
Well it appears to have been the ECM on the wheel well. After replacing just about everything they told me tonight the module was bad. Still not convinced myself but will know in the morning. I changed out the starter, ignition coil, regulator, a complete new distributor.I'm also going to unlock and clean the engine ground. After hours of reading why these modules go bad it appears either heat or a short is the most common reasons. The module they told me is bad is only 2 years old. This all started last week when the new battery drained overnight. The reason I replaced the regulator was because when I hooked up the battery charger it got hot as hell. The key was left in the on position was the reason. The man at the parts store said it probably burnt out the ECM. HOPEFULLY tomorrow well be back up and running.
Redfishtony
Thomasville, GA.
69' U152
351W
Mostly Stock
#6 Bully Bob
  • Moderators
  • 3854 posts
  • Gender:Male
    "Bully Bob"
Posted 05 June 2017 - 01:52 PM
What's the latest..?
#7 redfishtony
redfishtony
  • Members
  • PipPipPip
  • 27 posts
  • Gender:Male
Posted 09 June 2017 - 05:48 PM
Top Gun, Been bust so I haven't been checking up on things. I replaced everything and it cranked up and ran like a top. After about 10 minutes we shut it off and guess what, nothing. I was mad as a wet hen but was convinced it was something strange going on. At that point I tried jumping it and while doing so the positive battery cable made a strange spark. After a closer look, where the red insulation went under the lead post cover or cable end, the copper wires inside were almost corroded completely away. Switched it out with a new one and all is good. It was something so simple all along but was not visible due to the plastic coating on the wire. New fuel tank, lines and filter going in tomorrow. Thanks for checking. TW
Edited by redfishtony, 09 June 2017 - 06:01 PM.
Redfishtony
Thomasville, GA.
69' U152
351W
Mostly Stock
#8 Bully Bob
  • Moderators
  • 3854 posts
  • Gender:Male
    "Bully Bob"
Posted 09 June 2017 - 07:14 PM
KEWL...!!
Good job..!   Ya., sometimes the simplest issues are the hardest to find.
Keep us posted & some pics if ya have time...
Reply to this topic
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
